quelques liens
Page 2 sur 2 Précédent  1, 2
Re: quelques liens
Message  djédjé le Mer 25 Jan - 8:57
Pour Lizard et les crawleux bouillasseux! Laughing lol! flower
Re: quelques liens
Message  patron le Mer 25 Jan - 9:41
je vais tester le 1501mg sur nos crawler Smile
Servo Turnigy 1501MG analogique Taille standard Pignons metal 17kg
Model: TGY-1501MG
Voltage: 4.8~6.0v
Speed: 0.16~0.14sec
Torque: 15.5~17.0kg/cm
Weight: 60g
servo liens en france
Turnigy TGY-1501MG High Speed High Torque Metal Gear Servo - 17kg/cm 0.14sec - Waterproof
This standard size Turnigy metal gear servo is designed to give the perfect balance of high torque and high speed, ideal for monster trucks and a great upgrade for almost any stock servo, and fully Waterproof!
Includes servo horns and accessories, with a JR type connector (fits most receivers, check polarity, orange wire = signal/white).
Servo comparison (all @ 6v)
Turnigy TGY-1501MG 17kg/cm 0.14sec Significant performance improvement over stock servos.
Traxxas Digital Waterproof 2075 9kg/cm 0.17sec Typical 1/8th scale servo, stock on all Traxxas MTs.
Futaba Standard S3003 4.1kg/cm 0.19sec Typical standard servo used in 1/10th scale.
Re: quelques liens
Message  patron le Mer 25 Jan - 9:44
Hobbyking 4015DX Coreless Digital MG Servo, high voltage 6v~7.2v with alloy heatsink casing.
Specifications:
Weight: 60g
Direction: Counter-Clockwise/pulse travelling 1000~2000us
Dimensions: 40.2 x 20.3 x 38.8mm
Operating Voltage: 6v~7.2v
Torque: 14kg/cm @ 6v, 15kg/cm @ 7.2v
Speed (sec/60 deg): 0.14 @ 6v, 0.15 @ 7.2v
Motor Type: Coreless
Middle Case: Aluminium Heat Sink
Lead/Plug: JR Type 300mm
Dual Ball Bearing
Metal Gear
Re: quelques liens
Message  patron le Mer 25 Jan - 10:55
je me pausais la question suivante
pourquoi ne pas monter un Speed 720 BB Torque avec Bague d'adaptation SPEED 600 / SPEED 700
(Pour adapter un moteur SPEED 700 sur un emplacement de SPEED 600)
ou un
- Moteur Charbon Titan 775
- Variateur Electronique EVX-2 16.8v
caractéristique du 720bb torque
Monté sur 2 roulements à billes avec induit à 8 pôles.
Moteurs spéciaux à grande puissance avec antiparasitage intégré. Un couple élevé à faible régime les destine particulièrement pour l'équipement des grands modèles de bateaux avec une propulsion en prise directe et une grosse hélice.
Tension nominale 12 V
Plage de tension d'alimentation 6 ... 13 V
Régime de rotation à vide 4100 tr/mn
Consommation à vide 0,75 A
Consommation au rendement maximum 3 A
Consommation au blocage 13,5 A
Rendement max., sans réducteur 75 %
Longueur du carter, sans l'arbre 72 mm
Diamètre 44,5 mm
Longueur libre de l'arbre 6,5 mm
Diamètre de l'arbre 5 mm
Poids 380 g
Re: quelques liens
Message  patron le Ven 27 Jan - 4:46
Re: quelques liens
Message  patron le Ven 27 Jan - 12:22
je viens de recevoir les servo de juju
LES PHOTOS DES SERVO
VOUS REGARDEREZ MAIS LES JOINTS D’ÉTANCHÉITÉS SONT BIEN PRÉSENT
Re: quelques liens
Message  patron le Lun 30 Jan - 13:23
Re: quelques liens
